Supports break free and wreak havoc
Posted: Sun Apr 01, 2018 8:49 pm
by mentaluproar
During an overnight print, supports broke free and turned my lantern into a bird’s nest. The lantern itself was stuck strong to the PEI so I’m not sure how to fix this. Help?
Re: Supports break free and wreak havoc
Posted: Sun Apr 01, 2018 9:04 pm
by zemlin
how 'bout you post some helpful information about what you're doing. A copy of the factory file would be useful. Any photos you have.
What material are you running?
Are you using any Support Base Layers? I use 2 to lay down a good base for the support to build on.
What are your Support Infill Angles set to? I use 45 and -45 to tie the layers together for a stronger structure.
