Need help reducing PVA stringing on Qidi Tech 1
Posted: Mon Apr 02, 2018 5:28 pm
Hey all,
I'm trying to get my dual extruder Qidi Tech 1 (essentially a FlashForge Creator Pro clone) working with PVA so I can start using it for dissolvable supports. I've managed to get most of the settings dialed in, any my benchy prints pretty well (see attached) with good detail and good bed adherence. (Not that I stopped the print after bridging of the front window)
However, there is way too much stringing. I've been using the 10 minute calibration test (https://www.thingiverse.com/thing:1815784) to play with retraction and temperature, with no luck. No matter what I've tried, stringing remains about the same, as you can see from the five different tests I printed.
Here are the settings I've been adjusting and the ranges:
extruder temperature: 180 to 195 in 5d increments
retraction: 1 mm to 7 mm
retraction speed: 20 mm, 25 mm, 60 mm
Coasting: off and on with value of 0.2 mm
zlift: off and on with a value of 0.4 mm
[EDIT] I am printing at 0.1 mm resolution
Frankly, I'm at a loss, I would have thought at least one of these parameters would have changed things, but stringing seems to be virtually identical no matter what I did. (note, some prints I cancelled part way through because it was obvious stringing was the same. That's why some of the column heights are different)
Any suggestions on what I can try next?
Norm
Norm
