amp1276
Pause at layer
Please add the option to pause at a specified layer so that we can change colors. Also begin at layer would be good as well so that we can continue a stopped print.
rrdavis
Re: Pause at layer
There's already several ways to pause a print at a specific location.
You can also already use the "begin printing at height" option on the Advanced tab to resume a print at a certain Z-height.
airscapes
Re: Pause at layer
Lack of documentation seems to be a problem with S3D, the stuff they have on the site is good, just not even close to being enough..
This will explain the separate process.. and I saw a post or article someplace that explained how to add some gcode to the the end process script that would move the bed for filament change and the some to add to the start of the next process to put things back where they need to be..
https://www.simplify3d.com/support/tuto ... f-a-model/
PeterMorphett
Re: Pause at layer
Yes please at a simple pause at layer height setting, and offset the hotend without it also turning the hot end off, or bed temp.
Pete.
