I am using a single nozzle, dual extruder (Y configuration), and I enabled Prime Pillar
The problem is that when it's done with the Prime Pillar, it does not apply the setting in the first tab "Extruder", it does not retract, and lift nozzle before it moves to the location of the object where it starts printing with new colour.
Is there a setting I missed?
If I ALSO enable the Ooze Shield, then it retracts, and lifts the nozzle to go to the Ooze Shield, but when the ooze shield is done, it still does not lift nozzle and retract when it goes to the part.
Here is a screen shot without ooze shield:
When I enable ooze shield, you can see it lifts, and retracts to it, but not after the ooze shield is done going to the object:
I don't need ooze shield by the way. i am only showing this because I noticed that it DOES lift and retract when going to the ooze shield, but it still does not do it when it goes to the part
I want it to lift the nozzle and retract when going from the prime pillar to the part
