Hey all,
Simplify version 3.0.0
Looking to attach an object to the right side of the extruder on an R1+ ROBO 3D printer as part of my research, and need to limit the x-dimension of the bed so as to prevent hitting said object against the right side of the R1.
I edited the build volume dimension from 228 mm to 115 mm, which didn't seem to affect the G29 x-dimension.
As of now, G29 is doing a 9-point probe throughout the bed, I tried editing it as such in the startup code:
G29 X3 Y3 L10 R150 B150;
Which is a command that I thought would work with Marlin type firmware, but I'm new to such edits.
Any suggestions? Your time is much appreciated.
Best,
Jason
