Drednox
Single layer font
Mon Sep 24, 2018 9:54 am
I'd like to see an option for a single layer line font on the top surfaces. like lettering on a cake. it would be nice for very small lettering, signatures, and custom graphics. For example, I regularly print parts that require ID numbers. I print them at .4 layer height for speed and strength. For some, the only area I can add text without compromising structural integrity is so small the text is unreadable, and adding text to the vertical surfaces either weakens the part or causes unacceptable surface defects.
zemlin
Re: Single layer font
Mon Sep 24, 2018 7:19 pm
I like that idea, but it borders adding modeling features to a slicing program - and geometry creation is a whole different animal from slicing. From a feature standpoint, perhaps it could be handled as a way to handle single-layer geometry so it does not impact the underlying infill pattern. It's probably a possibility now if one uses multiple models and processes along with the newer thin-wall handling.
