Top Layer forgotten by simplify3D
Posted: Sun Feb 03, 2019 10:51 am
by azurha
Hello o/
I am in trouble !
I have already printed a lot.
After a long break, i re-installed simplify3D.
But simplify3D does not finish my models, it is stop before the top layer, on the all parts, any idea please ?
Re: Top Layer forgotten by simplify3D
Posted: Mon Feb 04, 2019 7:33 pm
by Squirts
I’ve been seeing this issue for thin wall on other forums for 4.1, which I’m having the same issue.
I hope there is a fix for it soon. I just bought this in December and I’m starting to regret it.
Posted: Tue Feb 05, 2019 1:03 pm
by jlovett
My co-worker and I have seen this a couple of times with a print, but only partially. There were gaps in the top layer as if it just didn't generate the .gcode for the finished product completely. I'm not sure why this happened.
Posted: Tue Feb 05, 2019 1:29 pm
by S3D-Alex
Thank you all for the reports. Can anybody please post a Factory File that shows what they are referring to?
Posted: Tue Feb 05, 2019 7:21 pm
by azurha
Did you speak about the .gcode ?
Posted: Sat Feb 09, 2019 9:57 am
by azurha
up
Posted: Sat Feb 09, 2019 11:50 am
Factory file...… File Menu===> Save Factory File.
The saved file contains everything needed to allow someone to load and see exactly what you see when you have your part and profile loaded.
A factory file is by far the most preferred way of allowing someone to see what you're experiencing....
Posted: Sun Feb 10, 2019 8:41 am
by azurha
i have the same problem with cura Oo
Posted: Sun Feb 10, 2019 9:08 am
Believe it or not......thin walls!
Change the option to allow single extrusion walls....and the missing layer will print. Not very well….but it slices.
Now do you see why a factory file is so important when diagnosing issues????
