azurha
Top Layer forgotten by simplify3D
Hello o/
I am in trouble !
I have already printed a lot.
After a long break, i re-installed simplify3D.
But simplify3D does not finish my models, it is stop before the top layer, on the all parts, any idea please ?
Squirts
Re: Top Layer forgotten by simplify3D
I’ve been seeing this issue for thin wall on other forums for 4.1, which I’m having the same issue.
I hope there is a fix for it soon. I just bought this in December and I’m starting to regret it.
jlovett
My co-worker and I have seen this a couple of times with a print, but only partially. There were gaps in the top layer as if it just didn't generate the .gcode for the finished product completely. I'm not sure why this happened.
S3D-Alex
Thank you all for the reports. Can anybody please post a Factory File that shows what they are referring to?
azurha
Did you speak about the .gcode ?
Ipad.gcode
(23.21 KiB) Downloaded 213 times
azurha
up
Factory file...… File Menu===> Save Factory File.
The saved file contains everything needed to allow someone to load and see exactly what you see when you have your part and profile loaded.
A factory file is by far the most preferred way of allowing someone to see what you're experiencing....
azurha
i have the same problem with cura Oo
ipadBlocker.factory
(47.49 KiB) Downloaded 275 times
Believe it or not......thin walls!
Change the option to allow single extrusion walls....and the missing layer will print. Not very well….but it slices.
Now do you see why a factory file is so important when diagnosing issues????
