TheRiddick
Bottom layer holes being FILLED in
Sat Mar 05, 2016 6:00 pm
I have a print where there are 2 holes in the bottom layer (could be second layer, hard to tell.), however S3D is auto filling in the holes for the first layer which is annoying as I must cut them out. Does anyone know what is going on here?
The model has NO errors and shows in the before prepare to print screen holes are present.
TheRiddick
Re: Bottom layer holes being FILLED in
Sat Mar 05, 2016 6:13 pm
Here is the problem
TheRiddick
Sat Mar 05, 2016 6:31 pm
Found a solution, changed layer height to 0.201 as suggested on another thread. All good now, must be some invisible problem with the model, but this will do as a fix.
KC_703
Sun Mar 06, 2016 1:16 pm
Uneven, poorly designed parts... suck. :)
I was going to suggest checking if the objects were manifold. If not, run them through netfabb.
arobg
Fri Mar 11, 2016 6:42 pm
Thank you for posting a solution. Simplify3D filled in the hole and created unnecessary bridging on the first layer of ro_base.stl from http://www.thingiverse.com/thing:1211594 , I changed the layer height from .500 to .499 and the file was sliced sanely.
TheRiddick wrote:Found a solution, changed layer height to 0.201 as suggested on another thread. All good now, must be some invisible problem with the model, but this will do as a fix.
Fri Mar 11, 2016 8:07 pm
For info, the correct solution is to sort out the errors that exist in the mesh. This can be done by running the model through a utility like NetFabb, or using the online repair tool at https://netfabb.azurewebsites.net/.
Changing the layer thickness is a trick that works some of the time as it changes the absolute height at which the current layer is being processed and this height so happens to miss the error in the mesh.
arobg
Tue Mar 15, 2016 7:39 pm
KC_703 wrote:...run them through netfabb.
dkightley wrote:For info, the correct solution is to sort out the errors that exist in the mesh. ...
Ah, yet another aspect of a subject that I don't know "what I don't know". Thank you for pointing out the slicing behavior of filling what I expected to be a hole as a symptom of a mesh problem and listing resources that fix this.
I ran the files of http://www.thingiverse.com/thing:1211594 through https://netfabb.azurewebsites.net/ and the files now slice as desired.
Thank you.
Shrike2012
Fri Mar 25, 2016 11:34 am
I had the same issue with a model and found that by turning off the "Merge all outlines into a single model" option on the Advanced tab fixed it.. Hope that helps..
Mark
