I want option to have BOTH generated supports AND manual supports. Because when there needs much supports, the automatic does not put supports
on every place it is needed, and i don't want to manually add kazillions of supports
So after auto supports is made i want to be able to add some more manually.
And also i have noticed that when adding manual supports inside a model, it is impossible to do unless you can actually SEE the place to add it to inside the model.
Even if crosssection is on.
