Hello,
I have a printer with one extruder, a printed bed and a heated camber.
According to the pcb layout, Extruder is T0, Bed is T1 and Chamber (actually "extruder 2") is T2.
The board is a ramps 1.4
Now, in the FFF settings, under the Temperature tab the "primary extruder" is configured as T0, and that works fine.
The bed is configured as T1 and it also works fine
the chamber however I don't know which Temperature Identifier to use.
In the Machine Control Panel I can select the active toolhead, and when I take toolhead 0, that's the extruder1
when I take toolhead 1, that strangely is NOT the bed, but it's my chamber! Because when I warm that temperature sensor, the readout of toolhead 1 increases.
I can't find my bed in any of those toolheads, so what I'm thinking is that I'm mixing up T0, T1, T2, .... and Tool0, Tool1, Tool2, ... to be the same.
Is that the case? Are these two things, actually different things that I must not mix up?
If so, is it correct that in the FFF settings I should select T2 for my chamber?
ANOTHER PROBLEM:
I want to set the temperature for the chamber to 50degrees C and for my extruder 240degrees C.
Every time when I change the temperature of tool 1 to 50, tool 0 also changes back to 50.. why can't I have two different values?
Kind regards
