lucpet
Re: Request for .3MF Support
Here is one that will convert 3mf files http://www.nchsoftware.com/3dconverter/index.html
ofloveandhate
@lucpet that converter is windows only :(
dorsai3d
Here's an open source converter: https://github.com/lemgandi/3mf2stl
jrpmedia
eandersen wrote:https://azure.netfabb.com/ gave me an STL file while https://tools3d.azurewebsites.net/ gave me a 3mf
In any case, it seems like the industry is heading toward 3MF and it would be great if S3D could support it.
azure.netfabb.com
Requires a Login and it appears not to be your Microsoft one or ID
IDM Imagineering
Professional Equipment for SuperHEROs.
https://www.idmimagineering.co.uk
jartza
One voice for .3MF support too, it seems to gain more and more support all the time, also free alternative slicers seem to support it already (Slic3r and Cura).
JD95
It would be nice to get 3MF support for multicolor / multimaterial objects as well.
bbinnard
I stopped using free NetFabb - both stand alone and on the MS Azure site) months ago and switched to 3D Builder exclusively. I've never had a problem with saving my corrected and simplified files at STL files. Maybe you have to be running native Windows 10 for this - which I do.
Paintball Magic
Just wanted to say thanks for adding .3mf support!
Simplify3d is worth every penny.
3MF file support has now been added in Simplify3D Version 4.0. You can import a 3MF file by dragging it into the application or clicking on the Import button and selecting the file. Hopefully this helps for any programs that may be using this new file format!
