dennisjm
Duel extruder setup - broken infill
EDIT: the object was broken, the process worked fine on a different object.
I'm not sure what I'm doing wrong here, perhaps someone can point out the correct process.
* I have a support material in one extruder of a duel extruder machine (Flashforge creator X)
* I want to generate some infill in the object (not with support material, just the normal plastic)
* Just started out with the stock profile for duel extruder prints but no matter what I change I can't seem to get infill turned on.
The idea is to print the external support structures out of HIPS. I know this is a very commonly done thing so there must be something simple I'm missing. I haven't actually tried printing anything I just notice I can't seem to get the infill to print inside the object.
tank_test.factory
(219.01 KiB) Downloaded 194 times
dennisjm
Re: Duel extruder setup - broken infill
Actually I just downloaded that object as a test. Apparently the object itself is broken it seems.
Will try with a different object.
