JonS
[Craftbot Flow IDEX] Fan speed (M106) Using "P" Not "T"
I'm using 5.1 with my Craftbot Flow IDEX. It's generating M106 fan speed codes with "P" to index the tool, while the Craftbot using "T" (T0/T1).
How can I resolve this? Can the post processing scripts be used to replace strings?
p.s. I didn't have this issue when I was using 4.1
Re: [Craftbot Flow IDEX] Fan speed (M106) Using "P" Not "T"
There's already a few threads about this on the forum if you search for it. Here's one that had a post-processing command you could use:
viewtopic.php?p=63519#p63519
JonS
S3D-Jason wrote: ↑Thu May 18, 2023 12:57 pm There's already a few threads about this on the forum if you search for it. Here's one that had a post-processing command you could use:
Thank you for the reply and pointer. My attempt at a search was a failure, so I'm not sure I would have found this.
