Don
Merry Christmas!
For this week I'm running my Astrolabe Ornament for free.
http://donfoley.com/3d-printing/project ... e-ornament
I couldn't do the work I do without Simplify3D.
Print this puppy for your friends and neighbors.
Don
Re: Merry Christmas!
awesome don! thanks a bunch. i just downloaded it.
dsegel
Thanks, I've been looking at that one for a while. Just downloaded it and purchased the Curiosity model as well to support your work.
ETA: I had a minor problem with the Curiosity model; sent you a message via your website.
Don
Thanks for your input folks.
Dsegel, I think you were the person who asked about the curiosity. Yes, some of my models have some small 'issues' that result in flipped polygons. Often is is a duplicated line or something. This would be an issue if I was printing with supports, since the program couldn't define the area to put the supports. But it will print just fine. On the rare occasion that I build a model that needs supports, I pay a LOT of attention to make sure it works fine. Thanks for your input!
tri-lite
This is also posted on the S3D Facebook page: https://www.facebook.com/pages/Simplify ... 9471868405
Edwin
with the Christmas I finally found what about even my wife likes it and wants more.
The astrolabe of Don's been great ..... thanks
On this I have the same time the Golden PLA used by iGo3D.
Well, the correct settings, I have not found yet. To print the filament at the same speed as I was used to it I must 10 ° C warmer at 220 ° C 0.15mm layer height, 43mm / s with a 0.5 mm nozzle print, and yet it is somehow a little pixelization occurs, but I'm still there and just running a second astrolabe.
Greetings Edwin
Don
Edwin,
Very cool, thanks for sharing.
I found that printing this thing slowly helps with all the little detail. I print mine in PLA at 205° at 0.10 mm layer height and 1500 mm/minute. It takes longer, but it's going to print all night anyway, so no reason to rush.
Don
Edwin
Hi Don,
the result is far probably only because of the filament so concluded. If I use a familiar to me I get quite adere surfaces and at higher speed and lower temperature.
When I print with this filament 205 ° C crumbles only, alas when I print very slowly.
I have therefore now times a pressure with ABS begun, which produces much nicer surfaces. I wil then like you are simply painting it. The Golden filament does not like anyway from gold and I would have had to painting it.
Greetings Edwin
Edwin
Hi Don,
I now have printed it once with ABS and a filament that I know
0.15 Layer Height and 40mm / s on a glass plate coated with UHU glue stick and 70 ° C
This surface can PLA also print on a cold bed if you previously dry the glue stick with a hair dryer and it holds about 20 prints. From tape I'm long gone.
There are still a few places that you can do better, but 10 minutes rework and assembly.
And here then painted.
Greetings Edwin
tri-lite
How impressive. Beautiful model from design and print from Edwin. Edwin's wife is going to be very happy, indeed.
