EVO1
Extrusion multiplier separation top layer infill / top layer perimeter
How can I controll the extrusion multiplier for the top layer infill and for the perimeters seperately?
EVO1
Re: Extrusion multiplier separation top layer infill / top layer perimeter
Can I set somehow the extruder tool number for a specific feature type like "; feature solid layer" in the post process ?
EVO1
Topic can be closed, I will manage it this way:
{REPLACE "; feature solid layer" "; feature solid layer \nM204 P3000.00 R30000.00 T1000.00 \nM205 B20000.00 S0.00 T0.00 X15 Y15 Z2.00 E100 \nM221 S95 "}
S3D-Taylor
The "Top Layer Extrusion Modifier" already does exactly that. It changes the extrusion multiplier for the top layer infill only, you can verify this by using the Flow rate coloring in the print preview mode. I've attached a screenshot that demonstrates this.
EVO1
This does not effect all solid layers or?
S3D-Taylor
This only affects all top layers.
