ExpertReward
FF Adventurer 5M "out of range" print error
I've just upgraded my printer from an Ender 3 to an FF AD5M being a user of Simplify3D I set the new printer up in with the help of support who supplied the missing printer profile. However I cannot start a print job I get "out of range" error, I have looked at the GCode for the print out and capture it also from Orca slicer. The Orca slicer sends loads of stuff include an image for display but I have just shown actual code start.
Start of S3D Code:
; G-Code generated by Simplify3D(R) Version 5.1.2
; Sep 24, 2025 at 10:22:34 PM
; Settings Summary
M107
;right_extruder_material: PLA
Q603 MINX98.17 MAXX131.83 MINY98.17 MAXY131.83 Z2.80 T0
M140 S60 ; set build platform temperature
M104 S220 T0 ; set extruder temperature
M104 S0 T1 ; set extruder temperature
G90 ; absolute coordinates
G28 ; home all axes
T0 ; select tool
G92 E0 ; zero extruder
G1 X105 Y105 Z0.2 F1000 ; move to prime
G1 X0 E10 F600 ; prime line
; process FFPLA-Basic0.4
; layer 1, Z = 0.2000
M108 T0
G92 E0.00000
G1 E-1.00000 F1800
; feature skirt
; tool H0.2000 W0.500
G1 Z0.2000 F1000
G1 X101.821 Y105.183 F18000
G92 E0.00000
G1 E1.00000 F1800
G92 E0.00000
Start of Code from Orca:
; EXECUTABLE_BLOCK_START
M73 P0 R3
M106 S0
M106 P2 S0
;TYPE:Custom
M190 S55
M104 S220
G90
M83
G1 Z5 F6000
G1 E-0.2 F800
G1 X110 Y-110 F6000
G1 E2 F800
G1 Y-110 X55 Z0.25 F4800
G1 X-55 E8 F2400
G1 Y-109.6 F2400
G1 X55 E5 F2400
G1 Y-110 X55 Z0.45 F4800
G1 X-55 E8 F2400
G1 Y-109.6 F2400
G1 X55 E5 F2400
G92 E0
G90
G21
M83 ; use relative distances for extrusion
; filament start gcode
SET_PRESSURE_ADVANCE ADVANCE=0.025; Override pressure advance value
M106 S0
M106 P2 S0
I've never actually looked at GCode so any help will be great.
Re: FF Adventurer 5M "out of range" print error
Did you already try emailing the person who sent you the profile? That's probably the best way to get feedback. I would also recommend sharing what firmware version you have since that might change the behavior.
