parallyze
Re: Bottom Solid Layers
brian444 wrote: ↑Thu Aug 20, 2020 8:37 pm This is an old print, but, i have the exact problem, which i am trying to resolve.
As far as I know Simplify3D doesn't keep the amount of material the same when reducing 1st layer height since v4.1:
viewtopic.php?t=12227
So many of the assumptions in this old thread aren't valid any longer.
parallyze wrote: ↑Fri Aug 21, 2020 9:51 am Hi,
Thanks for pointing this out, parallyze. You're correct. If you wish to squish the filament like in prior versions you can use the Global G-Code offsets in the G-Code tab. (Decrease on Z to squish more, increase on Z to squish less)
