kabali16
Re: solution to show estimaed print time needed with cubicon
Martin3d wrote:
if anyone how how to find the print time, here are both HVS files from cubicreator and simplify3d:
https://www.dropbox.com/sh/9n0m5je1c0ci ... kgX9a?dl=0
gcode compare find print time in gcode
cheers,
Martin
When you compare the gcodes from both software, you can see a few mcode commands in the beginning of the gcode..
M910 S793
M914 S250000
M915 S121449
914 is the Baud rate, Maybe one of the other 2 commands is responsible for sending the build estimate data to the firmware. Try including that in the S3D gcode and see if that displays the build time on the LCD
Kabali daww!!
Prusa i3 | Kossel
