Re: X-Axis Jog Control on Creatr
Posted: Tue Jan 21, 2014 6:52 am
Festus440 wrote:So a little more testing.
I printed a part and afterwards the left jog problem was there.
I hit disconnect in the software, turned the printer off, and unplugged the usb cable from the computer.
I waited 60 seconds, hooked everything back up and hit connect in Creater.
Without turning any heaters on the left jog problem was still occuring.
To get things working normally I had to restart Creater.
I did this more than once with the same results.
As I said before it's not just Creater.
It also doesn't always happen as soon as I turn the heaters on.
The above test procedure and the fact that it doesn't always happen, excludes firmware code (not settings). If it was firmware code, you would always be able to reproduce the problem with the same process.
So this leaves a few options:
Take a careful look/sound check on X-Axis stepper motor and make sure you don't hear a high pitch squeak when the stepper is supposed to start. This could indicate that the stepper is not getting the power it needs or that the pulses it receives are to fast. If the X-Axis stepper would be skipping, you would also notice that the X-Axis reading in for example Repetier no longer matches when you measure the X-Axis distance from the X-Axis left bracket (where you X-switch is).
In order to exclude that the stepping speed is to high, I would recommend to write down the EEPROM values (you can read them using with Repetier) and next tune-down the speed of the X-Axis. Just start with 50% less speed and 50% less acceleration and see what happens. Make sure that you save your setting in the EEPROM menu and restart the machine each time so it will load the new values.
Let me know the results and the default EEPROM setting and the reduced values you loaded in the Creatr, so we can consider next steps.
Rgds, Arno
