shocksofmighty wrote:It doesn't seem to be an issue with the firmware, just the ability of S3D to override the firmware variable from an imported profile. Again, just switching to the "Default" protocol and modifying everything to fit the printer and change the Z dimension to 170 mm was all it took. Note: I also changed the end script to to G1 170 instead of G1 150. You don't want things going back up after making a tall print.
I did exactly this, and my machine still stopped at 150. im using sailfish 7.7. what did you do exactly? can you include all the steps?
