Re: Surfaces you can see should be printed slow, all else fast
Posted: Sun Oct 22, 2023 6:00 pm
There is a work-a-round. You can create multiple processes. This is pretty easy in Simplify3D. This might not be perfect but should work quite well. Therfore you would have around 4-5 different process. You have to determine the height in mm as a starting point and an end point for each process.
