Page 2 of 2
Re: Qidi X-Pro Amazon review with potentially useful setting
Posted: Wed Dec 20, 2017 2:20 am
by rseal
Here's a factory file that hopefully contains 2 processes, one for the left and one for the right, both for PLA temps/settings. The only real difference beyond the choice of extruder is one line in the startup script, which apparently controls the extruder motor during the initial pass (I'll look more into this at some point).
The FFF files appear completely pointless. I'm assuming that the factory file contains the processes I've created, which is what I wanted to give you. Honestly, there appears to be no way to export an individual process. I write software and build hardware for a living, so this kind of thing really sets me on fire, especially given the small effort required by the developer. Anyway, enough complaining for now.
Let me know if this gives you what you wanted. If not I can put them in a text file and send them over.
Ryan
Posted: Wed Dec 20, 2017 6:10 am
by chase
You rock, Sir! I'll give it a shot as soon as possible when work, kids, girlfriend and Christmas allow...
Chase
Posted: Wed Dec 20, 2017 11:00 pm
by chase
It's working! I have it set to high quality, so I'm running a 1 inch cube and a test piece that should interface with a machined part if it's dimensionally correct. So far, the edge quality is much better than with the Qidi software.
You're my hero, Sir!
Posted: Thu Dec 21, 2017 1:35 pm
by chase
Next question:
I printed out a 1 inch cube using the high quality settings. When measuring it with a micrometer, it's about .995 on each side depending on whether it's measured at the top or in the middle.
Is there a master setting that consistently compensates for the -0.5% scaling error outside of scaling every STL at the time of import?
Chase
Posted: Thu Dec 21, 2017 4:10 pm
by rseal
Good to hear that you got things working. I'm not sure about the scaling, but you can adjust the extruder multiplier until you achieve the correct dimensions. Sounds like it's close though, maybe bump it up to 1.01 or 1.02, print, and adjust up/down from there. You may also want to fix the extruder width instead of using the "auto" setting. I haven't played with that setting enough to say one way or the other.
BTW, If you find your golden settings for PLA, please post.
Thanks,
Ryan
Posted: Fri Dec 22, 2017 12:31 am
by rseal
I was just browsing around the print troubleshooting guide they have on this site, it covers quite a few issues. If you find that the extrusion multiplier is not the issue, go to the "other" tab and take a look at the horizontal size compensation setting. You can use that to scale up/down in the XY plane. That'll definitely fix your problem. I was having some "pimple" problems on the edges of various prints. Enabling a 0.2mm coast appears to have fixed that issue.
Posted: Fri Dec 22, 2017 11:57 am
by chase
That was VERY helpful, thanks. Will test another cube today.
Meanwhile, the S3D customer service guy emailed me the official Qidi X-Pro profile, which is attached here.
Chase
EDIT: please contact the S3D support team if you need a copy of the profile
Posted: Fri Dec 22, 2017 1:37 pm
by rseal
Nice. I'll give that a try tonight.
Posted: Sun Dec 31, 2017 6:57 pm
by boatanchors
Chase
I downloaded the file and loaded the profile into S3D on my Mac...worked fantastically! The prints I am getting with it using a roll of the qidi-supplied PLA are significantly better than those produced with QIDIprint. This shouldn't be surprising, though, considering that QIDIprint is based upon an old version of Cura (2.6 IIRC) which wasn't particularly good to begin with.
Now, if QIDI could get the USB printer interface working so that I could hook the X-pro to OctoPrint on my OctoPi server, I'd be a happy camper! I have been working with the nice folks at QIDI for the last month or so, and keep nudging them as often as I can without being a PITA.
Walt
Posted: Wed Jan 03, 2018 12:42 pm
by chase
The S3D folks just emailed me an updated profile. I'm very impressed with their excellent level of attentiveness and support!
It's attached here.
Chase
