Re: CubePro Compatibility
Posted: Tue Mar 17, 2015 11:34 am
You're a little ahead of me in your dial-in!
I'm running out of material and haven't gotten my next shipment in yet, but i should have some this week.
For ABS, my track for dial-in is to ENSURE that the M108 value is 1/100th of the movement speed (at .2mm layer height). This will make calculating it on the fly easy. I've been monkeying with the extrusion width and temperatures to make this work, and i MIGHT be there--need to test with a real-world part, however.
Thus far it is:
Nozzle dia: .4
Extrusion Width: .44mm
Temp: 240.
On my calibration cube, i get good solid dimensionally accurate cubes and hole sizes that are .2mm undersized(doesn't seem to scale with hole size).
The top layer is a little underfilled when the cube isn't solid, but increasing the number of solid layers should fix this. (was at 4).
haven't tried real-world prints yet--or dual extruder prints. I look forward to learning as much as i can from YOUR work here! Keep it up and thanks for going thru this with us!
Thus far it is:
Nozzle dia: .4
Temp: 240.
