I tried the above. I told it to put the zipper in the middle of the surface of the 20mm cal cube wall and S3D ignored what i entered. Instead it started the layer in a corner. Seems to me "Choose Start point closest location" does not work as one may assume. Anyone know EXACTLY how it works and what it does?jimc wrote:you can gather the seam at one place in the model. in the layer tab choose "choose start point closest to location". it can be difficult to figure out exactly what the coords are where you need the seam so i modeled a 1mm dia x 10mm tall cylinder. i saved it as an stl and just called it "drop pin". when i need the seam in a specific location i will drop the pin on the table then drag it right where i want the seam. then i double click on it and read the coords of the pin. enter the coords into the process and remove the drop pin.
