Retraction Vertical Lift modifying printing height
Posted: Thu Jun 21, 2018 12:42 pm
by timcurtis67
When I try adding say .6mm in my retraction vertical lift setting S3D adds that amount to my first layer z height? So if I'm wanting my first layer to be .3mm thick it actually makes it .9mm for the first layer. Is there a work around for this? I need Z retracts for this part I'm printing.
I'm using S3d 4.0.0
Re: Retraction Vertical Lift modifying printing height
Posted: Thu Jun 21, 2018 1:46 pm
by DarthRevan
I'm using 4.0.1 and my first layers, even when using huge lifts like 1mm, I still have all my print moves printed at the correct height.
Are you seeing this in your prints or just the preview window's reporting of the Z position? I have noticed that when using retraction vertical lift along with preview by layer rathe than by line, the Z height reported is that of the last Z move in the layer, which would of course be the lifted height and not the actual layer's printed height.
Layer
Line (Taken 2 lines before the actual last line for layer 1)
Posted: Thu Jun 21, 2018 2:11 pm
by timcurtis67
I'm actually using 4.0.1. My issue is actually in the Gcode file. The first layer is trying to print at .9mm high. If I turn off the retraction vertical lift then my first later is at .3mm which is what I wanted.
It's got to be a bug? No one else noticed this yet?
Posted: Thu Jun 21, 2018 2:18 pm
by DarthRevan
I've not seen this happen to me. Can you attach your factory file?
Posted: Thu Jun 21, 2018 2:29 pm
by timcurtis67
Yes I will attach it later tonight when I get home. Maybe I have something else set wrong?
Posted: Thu Jun 21, 2018 3:58 pm
Read this thread: viewtopic.php?f=9&t=10274&p=42273&hilit=vertical#p42273
In particular the posts made by me.
If you understand what I have posted, you'll understand there is no bug! And you have nothing set wrong.
Posted: Mon Jun 25, 2018 11:41 am
by timcurtis67
Yeah it was my bad on that one. I looked father down in the gcode file and saw that the program starts out at the retract Z height and then drops to the correct height when the printing starts.
All is well.
