Ball form comes loose from bed
Posted: Wed Jul 04, 2018 3:47 am
Greetings,
I am printing a wheelpant with ABS , finally I am getting somewhere , but still some issues , I hopeone some can give me some pointers.
Printing this: After about 15-20-ish Layers , these 2 parts come loose. (ussing support 40%, support base layers 0 , dense support 0)
Last night I played araound with the support settings , made infill percentage 50% and dense support layers 1. Although I got a useable print the support is very thick , and way too much.
I think the problem is , since it is a pointy/ ball form , and almost does not touch the bed, after building on it , it becomes unstable after several layers and than just brakes off.
I use ABS -juice and everything sticks good on the bed, so I don't think that is the problem , the bed is also heated ( 100 degrees) and in an enclosure
Anyone has an idea how I can solve this?
Also the bottom part is very rough: Maybe due to the support? any solutions for this , although this is not the most important , I can sand it. But it would be nice if the bottom part of the model comes out a bit better.
Biggest issue is the 2 parts which touches the heatbed and comes loose , that is realy a pain .
Many thanks,
Cor
Many thanks,
Cor
