Dual Extruders
Posted: Sun Jun 01, 2014 2:49 pm
I have designed a jig which has legends on the top. What I was thinking was that I could print the base using process 1 which used the right extruder, and then at a given height switch to process 2 which prints using the other extruder (in another colour). This actually works, nearly.
My base is 4mm high. The legends sit on top of that. To ensure these legends were 'attached' to the base I configured the STL file so that the legends were sunk into the base by 0.2mm. I have attached a copy of that STL file. The 2 processes define the start/stop heights at where the processes begin/end.
What happens is that the legends do indeed print as expected. However they aren't firmly attached to the base - and minor pressure causes them to be physically removed.
Am I doing this right?
