Page 1 of 2
Creality CR-10S PRO profile
Posted: Fri Nov 23, 2018 9:18 pm
by shaka89
hi all,
I just got a Creality CR-10S PRO printer, but I can't seem to find a profile for it online.
I tried loading the gcode from the included test files, but S3D doesn't seem to like it ...
any help would be appreciate it.
Thank you!!!
Re: Creality CR-10S PRO profile
Posted: Tue Nov 27, 2018 1:39 pm
by Nismo370z
*bump - I've got a CR-10s Pro being delivered tonight.. Where can we get the profile for S3D?
I've also emailed support per the "compatibility checker" tool.. Wish they had a "downloads" section for registered users.
Posted: Thu Nov 29, 2018 11:51 pm
by cyborblades
Ditto I just got my CR10s Pro yesterday and I also could use a profile. The extruder and hotend are not standard CR10s. Been messing with settings trying to get it right but retractions are not the same and I have not been able to get it locked in.
Posted: Sun Dec 02, 2018 12:19 pm
by docrenatoms
I don't have this printer yet but I have a tip for you.
Click on "File" > "Import FFF profile" and choose the best gcode that came in the printer's SD Card. S3D will get the gcode's settings that will be the factory settings. It's always a good profile that needs small amount of tunning.
Posted: Mon Dec 10, 2018 3:03 pm
by MikeInAZ
I got this from someone else. Seems to be working nicely. Although I'm still getting some travel lines. Can't seem to shake them.
https://drive.google.com/file/d/1Zbc4GK ... sz-W2IVpa0
Posted: Thu Dec 13, 2018 5:58 pm
by oakmeadows
Hello i received my cr10 pro today and when i started simplicity3d i then went to help on the top bar of the software then clicked on configuration assistant then select cr10 and it will put in cr10 settings for you
hope this helps
Posted: Mon Dec 17, 2018 1:54 pm
by S3D-Chris
The CR-10S is functionally similar to the CR-10. We recommend using the CR-10 profile that is available in the Configuration Assistant.
Posted: Mon Dec 17, 2018 3:37 pm
by tonyno
Kinda OT... I'm thinking about getting one of these. Any thoughts yet? How about a suggested enclosure size?
Posted: Tue Dec 18, 2018 2:49 pm
by tocnaza
порно
porno zdarma
porno fete
Posted: Mon Jan 14, 2019 11:25 pm
by Sour_Pickel
Is there a valid CR-10S Pro profile yet?
