shaka89
Creality CR-10S PRO profile
Fri Nov 23, 2018 9:18 pm
hi all,
I just got a Creality CR-10S PRO printer, but I can't seem to find a profile for it online.
I tried loading the gcode from the included test files, but S3D doesn't seem to like it ...
any help would be appreciate it.
Thank you!!!
Nismo370z
Re: Creality CR-10S PRO profile
Tue Nov 27, 2018 1:39 pm
*bump - I've got a CR-10s Pro being delivered tonight.. Where can we get the profile for S3D?
I've also emailed support per the "compatibility checker" tool.. Wish they had a "downloads" section for registered users.
cyborblades
Thu Nov 29, 2018 11:51 pm
Ditto I just got my CR10s Pro yesterday and I also could use a profile. The extruder and hotend are not standard CR10s. Been messing with settings trying to get it right but retractions are not the same and I have not been able to get it locked in.
docrenatoms
Sun Dec 02, 2018 12:19 pm
I don't have this printer yet but I have a tip for you.
Click on "File" > "Import FFF profile" and choose the best gcode that came in the printer's SD Card. S3D will get the gcode's settings that will be the factory settings. It's always a good profile that needs small amount of tunning.
MikeInAZ
Mon Dec 10, 2018 3:03 pm
I got this from someone else. Seems to be working nicely. Although I'm still getting some travel lines. Can't seem to shake them.
https://drive.google.com/file/d/1Zbc4GK ... sz-W2IVpa0
oakmeadows
Thu Dec 13, 2018 5:58 pm
Hello i received my cr10 pro today and when i started simplicity3d i then went to help on the top bar of the software then clicked on configuration assistant then select cr10 and it will put in cr10 settings for you
hope this helps
S3D-Chris
Mon Dec 17, 2018 1:54 pm
The CR-10S is functionally similar to the CR-10. We recommend using the CR-10 profile that is available in the Configuration Assistant.
tonyno
Mon Dec 17, 2018 3:37 pm
Kinda OT... I'm thinking about getting one of these. Any thoughts yet? How about a suggested enclosure size?
tocnaza
Tue Dec 18, 2018 2:49 pm
порно
porno zdarma
porno fete
Sour_Pickel
Mon Jan 14, 2019 11:25 pm
Is there a valid CR-10S Pro profile yet?
