Page 1 of 2
Failed saving on network storage
Posted: Thu Dec 20, 2018 10:49 am
by sakphreak
Hi there,
I got S3D 4.1.1. When I try to save my GCode on my NAS, i get following failure. There's no problem when I want to save my GCode on my computer.
When I manually check the location, there's a GCode Temp-File in it with PROGRAMNAME.gcode.temp as name.
I also compared both files, they match 100%
Any advices how to get that away?
Greetings from germany,
Dennis
Re: Failed saving on network storage
Posted: Thu Dec 20, 2018 1:43 pm
by S3D-Jake
Are you running Simplify3D with administrator permissions?
Posted: Fri Dec 21, 2018 3:50 pm
by sakphreak
Yep, I'm running it with administrator permissions.
Also checked the shortcut option "Always run as admin".
Posted: Sun Dec 23, 2018 8:36 am
by sakphreak
Did test that, no difference when running as admin. Also checked the "Run as admin" box from the shortcut :|
€dit: I don't know why but my posts aren't posted live. sorry for doublepost. Still same problem!
Posted: Fri Dec 28, 2018 3:06 pm
by s3030150
same problem, S3D v4.1.1 running on both Macintosh and Windows. Message "Failed to execute post processing commands" keeps popping up after saving almost any gcode to a network path. It's happening as well when saving gcode to Toshiba FlashAir webdav share.
Note that saving the GCODE file onto Desktop and copying to the desired network drive works without problem. Local gigabit network or slower wifi, does not make any difference.
this problem did not appear in version 4.0.1 at all. Never seen that message in 4.0.1
my post-processing script is here, there's nothing more than that:
Code: Select all
{REPLACE "; feature outer perimeter\n" "; feature outer perimeter\nM204 P800\n"}
{REPLACE "; feature inner perimeter\n" "; feature inner perimeter\nM204 P1000\n"}
{REPLACE "; feature solid layer\n" "; feature solid layer\nM204 P1000\n"}
{REPLACE "; feature infill\n" "; feature infill\nM204 P3500\n"}
Posted: Thu Jan 10, 2019 12:25 pm
by S3D-Jake
After working with another user, the issue with running post processing commands seems to stem from the use of unicode characters (ä, ö, ü, eñe, kanji, etc...) in the file name or file path. Does your network storage or the name of the file you're saving use these unicode characters?
Posted: Thu Jan 10, 2019 1:11 pm
by wirlybird
S3D-Jake wrote: ↑Thu Jan 10, 2019 12:25 pm After working with another user, the issue with running post processing commands seems to stem from the use of unicode characters (ä, ö, ü, eñe, kanji, etc...) in the file name or file path. Does your network storage or the name of the file you're saving use these unicode characters?
Also make sure the full "path" name isn't too long or large. There are limits to how many characters and folder levels you can have.
Posted: Thu Jan 10, 2019 1:34 pm
by s3030150
nope, no special characters nor long path in my case.
http://10.0.0.9/ is mounted as /Volumes/10.0.0.9 with flags webdav, nodev, noexec, nosuid
if my problem came from some problem with path, it would happen every time. Sometimes it's enough to save the (previously saved with zero length + error message) file again and it saves correctly.
is there anything I can do to help identifying the problem? Does S3D log somewhere? this error message I'm getting with 4.1.1 is quite generic and does not say much
Posted: Fri Jan 11, 2019 9:36 am
by S3D-Jake
I'd try setting up another mount point without those flags for your G-code files to be saved and post processed. Post processing is executing commands on the already saved G-Code file, so at the least I'd suggest taking off the noexec flag.
Posted: Fri Jan 11, 2019 10:44 am
by s3030150
did not help unfortunately.
note that this is standard Mac disk mounting result. To be fair, it should work when I map the disk on the mac by pressing CMD+K and putting http://flashair_ip/ - it mounts and I should be able to use this drive.
I'm currently using version 4.0.1 which does not have this problem, at all. Also does not suffer from any vase mode problems
