Missing section in slice present in .stl file
Posted: Fri Jan 04, 2019 4:49 pm
by D.Clarke
For some reason I am missing a section / piece when printed.
It shows in the .stl file in preview but not after prep to print.
Attached are factory file. Preview and Prep images.
Re: Missing section in slice present in .stl file
Posted: Fri Jan 04, 2019 6:24 pm
Use the "Separate Connected Surface" option in the Mesh dropdown.
The problem is because the stl file that has been created by the CAD software has more than one mesh in it. Using the above option will separate the meshes out into sub-models. Once this is done, the missing pieces will slice and print.
Posted: Fri Jan 04, 2019 10:17 pm
by D.Clarke
Thank you!
