incorrect Z axis
Posted: Wed Jul 16, 2014 6:17 pm
Hello,
I have built a customized printer that is most similar to the makerbot replicator.
I use RAMPS1.4 and the newest repetier firmware.
I can move the printer manually and correctly with the Machine Control Panel.
When I press Home All then the Position Readout tells me:
x: 0.00
y: 170.00
z: 100.00
That means that y and z homing direction is max and x is min.
My Problem is the following:
When I want to print a part, the bed does not move up to the extruder and the extruder prints in the air. But the Position Readout for z is 0.18 wich would mean that the bed is 0.18mm under the extruder. In reality is in homing Position what means 199.00mm.
What is my mistake?
Flo
x: 0.00
y: 170.00
z: 100.00
What is my mistake?
Flo
