Re: Auto Pause after printing a layer
Posted: Mon Apr 15, 2019 2:30 pm
by S3D-Chris
You can do this by adding a terminal command for post processing in the Scripts tab. You will need to identify the layers (layer 5 is used as an example) you want to pause at and then enter a post processing script at the top of the additional terminal commands for post processing section as seen below:
{REPLACE "; layer 5" "G5/n;"}
Posted: Fri Apr 19, 2019 3:33 am
by horst.w
@ S3D-Chris
"G5" - your are sure ???
G5 is not listet in Reprap commands, it will be " G4 "
GER
Posted: Sun Apr 21, 2019 12:16 pm
by SteveYYC
If you want to change the filament and you're running compatible firmware, you might want to use "M600" instead of "G4"
http://marlinfw.org/docs/gcode/M600.html
Posted: Mon Apr 22, 2019 1:47 pm
by S3D-Chris
horst.w wrote: ↑Fri Apr 19, 2019 3:33 am @ S3D-Chris
GER
G5 is a Dremel specific pause command and will work for every Dremel printer besides the 3D20
Posted: Mon Apr 22, 2019 3:41 pm
by horst.w
Never turn out in the morning without learning something until the evening ...
H.
