Extruder Temperature Issues on a XYZPrinter Da Vinci 1.0 Pro
Posted: Wed Dec 18, 2019 10:32 pm
I’m having some extruder temperature issues using S3D. I have two 3D printers (Anet A8 and XYZPrinting Da Vinci 1.0 Pro). S3D works perfectly with the Anet A8. However, I’m having problems setting the extruder temperature on the Da Vinci. See summary below:
1st Scenario:
1. Extruder temp set to 190.
2. At about 185, the printer start to print.
3. The temp continues to raise until the temp gets to 200.
4. The temp stays at 200 until the print is complete.
2nd Scenario:
1. Extruder temp set to 210.
2. At about 200, the printer start to print.
3. The temp continues to raise until the temp gets to 220.
4. The temp stays at 220 until the print is complete.
S3D seems to add 10 degrees to whatever extruder temperature is selected.
1st Scenario:
2nd Scenario:
