"Unable to load file" when printing over USB
Posted: Mon May 25, 2020 4:45 pm
by rmsailors
Please help a Simplify3D newbie.
When trying to print a moderately complex model on a XYZPrinting Da Vinci Pro 3-in-1 (model is roughly: x 40mm, y 62mm, z 100 mm)
The print preparation process seems to complete smoothly, but when I try to print via USB, I get an error that says "Unable to load file" (paraphrasing).
I am trying to print with rafts and supports turned on.
Layer 0.20 mm
Top 4 layers
Bottom 4 layers
Outline shells 3
Honeycomb fill @ 60%
I am able to save to a file.
thanks in advance
Re: "Unable to load file" when printing over USB
Posted: Tue May 26, 2020 10:15 am
by cstraley
check what com port you are using then go to machine control panel and make sure that the baud rate and the com port is set right .
