FlashForge Adventurer III - Z OffSet
Posted: Sat Jul 11, 2020 12:07 pm
by gaawc3d
I got a brand new FlashForge Adventurer III and printing with no issues using FlashPrint. Trying to move to Simplify 3D and it is failing 100% of time, the extruder is to close with bed. I believe the issue is the Z offset.
I did a calibration of printer manually (using LCD) and the level now is -0.5.
I tried changing in G-Code tab, manipulating the Global G-Code Offsets to +0.5mm but no effects.
I have two questions:
1) What setting I have to apply in Simplify 3D to avoid the extruder getting to close with bed?
2) Does simplify 3d supports controlling FlashForge directly using network (ip control) ?
Thanks,
Re: FlashForge Adventurer III - Z OffSet
Posted: Mon Jul 13, 2020 2:54 pm
by parallyze
Adding a factory file might be helpful (File -> Save Factory File) here to have a look at your profile settings.
At what point is the nozzle to close to the bed, is it when the printer starts printing the object or is it a bit earlier,
maybe when some kind of "purge line" is supposed to be printed?
GCode offsets won't be applied to something like that inside the start scripts.
