Can't fix self-intersecting problem
Posted: Sun Aug 16, 2020 8:06 pm
by jeffmorris
When I repair one of the models in S3D, the model is manifold but I can't fix self-intersecting problem. I tried to fix it in STL editors but they don't work. S3D is supposed to highlight the problem but I can't find the highlighted problem.
Re: Can't fix self-intersecting problem
Posted: Mon Aug 17, 2020 10:42 am
by S3D-Alex
I was able to find the errors here but they are admittedly pretty small so probably won't cause any print issues. I included a screenshot below showing where the error is with the cross section view enabled.
Posted: Mon Aug 17, 2020 8:09 pm
by jeffmorris
How can I fix self-intersecting problems in Blender3D?
Posted: Tue Aug 18, 2020 4:53 pm
by jeffmorris
I used Autodesk Netfabb to fix the problems and 3D-printed the brake calipers without any problems. There were "holes" where you showed me the problems.
Posted: Sun Nov 01, 2020 5:45 pm
by CavanBaillie
I have had no luck using the repair tools in simplify3D.
Repetier Host has a fantastic manifold repair tool built in to their software. I repaired my model then exported as an stl then opened it in Simplify 3D and it works perfectly.
