jeffmorris
Can't fix self-intersecting problem
When I repair one of the models in S3D, the model is manifold but I can't fix self-intersecting problem. I tried to fix it in STL editors but they don't work. S3D is supposed to highlight the problem but I can't find the highlighted problem.
ED-013_D.stl
(835.73 KiB) Downloaded 179 times
S3D-Alex
Re: Can't fix self-intersecting problem
I was able to find the errors here but they are admittedly pretty small so probably won't cause any print issues. I included a screenshot below showing where the error is with the cross section view enabled.
jeffmorris
How can I fix self-intersecting problems in Blender3D?
jeffmorris
I used Autodesk Netfabb to fix the problems and 3D-printed the brake calipers without any problems. There were "holes" where you showed me the problems.
CavanBaillie
I have had no luck using the repair tools in simplify3D.
Repetier Host has a fantastic manifold repair tool built in to their software. I repaired my model then exported as an stl then opened it in Simplify 3D and it works perfectly.
