Resume print after failed thermistor
Posted: Fri Oct 17, 2014 8:21 am
G'day all,
I have a 27hour print and 3/4 of a spool of ABS that had a failed thermistor about 90% though the print, looks like the failure happened right near the end of a layer, so printer was merrily printing nothing when I came home today, arghhh!
so question is how do can I recover this?
I've had to power off to reset firmware after replacing the thermistor so I can't zero Z Axis due to the print on the print bed.
I have worked out what layer I need to print next, if I zero my Z Axis at the top of the print, how can I offset the part I ned to print so that it's layer is = 0 on the Z-Axis?
Regards,
Stephen...
Regards,
Stephen...
