Simplify freezing
Posted: Wed Jun 02, 2021 2:31 pm
by sstarek
Hello,
My Simplify v.4.1.2 is freezing when I trie to "Prepare to Print!"
It is stopping at the bar and does not load. I have to close the program and open it several times until it slices and sometimes it crashes when I'm going to save the Gcode I'm forced to close and open it again.
He keeps thinking and doesn't get out of that "Generating support structures..." or on the finish "Finished parsing G-Code file" bar
I've even tried to uninstall and install the program again and even so it still has this error.
Re: Simplify freezing
Posted: Mon Jun 07, 2021 10:34 am
by sstarek
I'm using windows 10 - 64 bits.
Posted: Mon Jun 07, 2021 10:40 am
by gwhite
I have not had this problem, and I run W10 64 bit as well.
I seem to recall other posts that mentioned issues with their graphics systems. You might check to see if your graphics card is running the latest drivers. You can also search the forum for any posts from users with the same graphics hardware.
Posted: Tue Jun 08, 2021 7:12 am
To expand on the last answer, issues that have caused freezing:
Bad stl file........try different stls, and run these two through a repair utility if you can slice other stls
Non-supported characters in the stl or profile names......rename using basic alphabet.
Corruption in profile........delete profile & recover from backup or an old factory file
WIndoes update to graphics driver causing issue with compatibility with your hardware...........restore previous driver, or load new driver from graphics card supplier.
These and more can be found by searching the forum
Posted: Tue Jun 08, 2021 8:37 am
by sstarek
gwhite wrote: ↑Mon Jun 07, 2021 10:40 am
It´s not my graphics card, I'm using a Nvidea Quadro and running solidworks without problem.
Dos someone know how to make a clean step up? Every time I trie to unistal and install all configs are back.
Posted: Tue Jun 08, 2021 8:42 am
by sstarek
dkightley wrote: ↑Tue Jun 08, 2021 7:12 am
I trie diferents (alot) stl files and same.
Just now I trie to use other profile and test, same think, sometimes frozen when "slicing 3D models" sometimes on save gcode...
The program don't frozen, I can turn the work pice, edit process settings, etc. But the bar "loading" is frozen. I can't even click cancel.
