Failed to execute post processing commands.
Posted: Fri Jul 02, 2021 9:43 pm
by Makita
I am getting the following error message when trying to save to SD Card "Failed to execute post processing commands."
Can't work out what is wrong. using Version 4.1.2
Cheers
Re: Failed to execute post processing commands.
Posted: Tue Jul 06, 2021 10:34 am
by S3D-Jake
Are you running Simplify3D as admin? Running as administrator should allow you to execute terminal commands when saving files to removable drives.
Posted: Fri Oct 28, 2022 2:16 pm
by mcbutler
S3D-Jake wrote: ↑Tue Jul 06, 2021 10:34 am Are you running Simplify3D as admin? Running as administrator should allow you to execute terminal commands when saving files to removable drives.
What does this mean exactly? I am on MB pro fully updated with same error S3d is unuseable!
Posted: Wed Nov 09, 2022 9:55 am
by S3D-Jake
You can try saving your g-code file to a local hard drive location such as your user's desktop. Then after it's been saved move it to a flash drive or SD card.
