Makita
Failed to execute post processing commands.
I am getting the following error message when trying to save to SD Card "Failed to execute post processing commands."
Can't work out what is wrong. using Version 4.1.2
Cheers
Re: Failed to execute post processing commands.
Are you running Simplify3D as admin? Running as administrator should allow you to execute terminal commands when saving files to removable drives.
mcbutler
S3D-Jake wrote: ↑Tue Jul 06, 2021 10:34 am Are you running Simplify3D as admin? Running as administrator should allow you to execute terminal commands when saving files to removable drives.
What does this mean exactly? I am on MB pro fully updated with same error S3d is unuseable!
You can try saving your g-code file to a local hard drive location such as your user's desktop. Then after it's been saved move it to a flash drive or SD card.
