Klipper Plugin PAM Simplify 3D Start Code
Posted: Tue Mar 22, 2022 1:36 pm
by tobias9009
i wanted to run the Klipper PAM Plugin cause im annoyed of waiting for long Time bed leveling.
For the Plugin there are two Start Code.
One for SuperSlicer/PrusaSlicer:
MESH_CONFIG X0={first_layer_print_min[0]} Y0={first_layer_print_min[1]} X1={first_layer_print_max[0]} Y1={first_layer_print_max[1]}
And one for Ideamaker:
MESH_CONFIG X0={print_pos_min_x} Y0={print_pos_min_y} X1={print_pos_max_x} Y1={print_pos_max_y}
Somebody know in which way i have to edit it to make it work on Simplify ?
Or where the documentation about this can be found ?
Re: Klipper Plugin PAM Simplify 3D Start Code
Posted: Tue Dec 20, 2022 1:24 pm
by ptegler
same boat...nothing from S3D staff? possible post processing to pickup the correct parameters to fill in the script in g-code file gene'ed by S3D?
Posted: Wed Dec 21, 2022 2:21 am
by SweHogelid
+1
Posted: Wed Dec 21, 2022 7:09 am
by S3D-Jason
I think you can already do this in V5. Here's the syntax to use:
MESH_CONFIG X0=[build_min_x] Y0=[build_min_y] X1=[build_max_x] Y1=[build_max_y]
Posted: Thu Dec 22, 2022 4:50 am
by SweHogelid
S3D-Jason wrote: ↑Wed Dec 21, 2022 7:09 am I think you can already do this in V5. Here's the syntax to use:
Thank you!
This worked perfectly.
Posted: Fri Feb 02, 2024 10:09 am
by amoe
Hey,
can someone please explain how I can get this syntax "MESH_CONFIG X0=[build_min_x] Y0=[build_min_y] X1=[build_max_x] Y1=[build_max_y] " to work with Simplify3d v5 and the K1 and K1 Max?
I have KAMP already installed, but when I insert the syntax to the starting script in S3D, the only thing that happens is, that the bed leveling is done by measuring the outer 4 corners of the printer's bed. I also noticed, that even without this syntax, but with KAMP installed, only the 4 outer corners are measured. By uninstalling KAMP all 25 points on the bed are measured.
Hope someone can help me setting this up.
Attached is a screenshot of the starting scrip with the syntax.
Best regards!
Posted: Sun Apr 07, 2024 5:41 am
by oz1bqq
I have found this:
