tobias9009
Klipper Plugin PAM Simplify 3D Start Code
i wanted to run the Klipper PAM Plugin cause im annoyed of waiting for long Time bed leveling.
For the Plugin there are two Start Code.
One for SuperSlicer/PrusaSlicer:
MESH_CONFIG X0={first_layer_print_min[0]} Y0={first_layer_print_min[1]} X1={first_layer_print_max[0]} Y1={first_layer_print_max[1]}
And one for Ideamaker:
MESH_CONFIG X0={print_pos_min_x} Y0={print_pos_min_y} X1={print_pos_max_x} Y1={print_pos_max_y}
Somebody know in which way i have to edit it to make it work on Simplify ?
Or where the documentation about this can be found ?
ptegler
Re: Klipper Plugin PAM Simplify 3D Start Code
same boat...nothing from S3D staff? possible post processing to pickup the correct parameters to fill in the script in g-code file gene'ed by S3D?
I think you can already do this in V5. Here's the syntax to use:
MESH_CONFIG X0=[build_min_x] Y0=[build_min_y] X1=[build_max_x] Y1=[build_max_y]
SweHogelid
S3D-Jason wrote: Wed Dec 21, 2022 7:09 am I think you can already do this in V5. Here's the syntax to use:
Thank you!
This worked perfectly.
amoe
Hey,
can someone please explain how I can get this syntax "MESH_CONFIG X0=[build_min_x] Y0=[build_min_y] X1=[build_max_x] Y1=[build_max_y] " to work with Simplify3d v5 and the K1 and K1 Max?
I have KAMP already installed, but when I insert the syntax to the starting script in S3D, the only thing that happens is, that the bed leveling is done by measuring the outer 4 corners of the printer's bed. I also noticed, that even without this syntax, but with KAMP installed, only the 4 outer corners are measured. By uninstalling KAMP all 25 points on the bed are measured.
Hope someone can help me setting this up.
Attached is a screenshot of the starting scrip with the syntax.
Best regards!
oz1bqq
I have found this:
MESH_CONFIG for Simplify3D.pdf
(69.58 KiB) Downloaded 511 times
