Is there a way to....
Posted: Tue Nov 18, 2014 6:22 pm
by FDWorx
Slow the gantry speed down from the home axis to the point where the extruder purges. Its a little too fast for my liking, its slamming the gantry.
Brian
Re: Is there a way to....
Posted: Tue Nov 18, 2014 6:34 pm
by dennisjm
Under the scripts tab find the starting gcode. There is probably something like
G1 X?? Y?? F???
Change the F to something slower.
Posted: Wed Nov 19, 2014 9:46 am
by KeyboardWarrior
FDWorx wrote:Slow the gantry speed down from the home axis to the point where the extruder purges. Its a little too fast for my liking, its slamming the gantry.
Brian
If you go to the Scripts tab, and copy-paste your starting G-Code, I could change the speeds for you.
Posted: Mon Nov 24, 2014 6:05 pm
by FDWorx
Brian
Thank You,
Brian
; **** Replicator 2X start.gcode ****
G161 Z F1200 ; home Z minimum
G92 Z-5 ; set Z to -5
G1 Z0 ; move Z to 0
G161 Z F100 ; home Z slowly
G1 X-130 Y-75 Z30 F9000 ; move to wait position off table
M126 S[fan_speed_pwm]
M140 S[bed0_temperature] T0
M133 T0 ; stabilize extruder temperature
G92 A0 B0 ; zero extruders
G1 Z0.4 ; position nozzle
G1 E25 F300 ; purge nozzle
G1 X-125 Y-70 Z0.15 F1200 ; slow wipe
G1 X-120 Y-65 Z0.5 F1200 ; lift
Posted: Mon Nov 24, 2014 8:21 pm
by KeyboardWarrior
Brian
Thank You,
Brian
G1 Z0 ; move Z to 0
Change that bolded section to F225 and let me know how that works for you
