FDWorx
Is there a way to....
Slow the gantry speed down from the home axis to the point where the extruder purges. Its a little too fast for my liking, its slamming the gantry.
Thanks
Brian
dennisjm
Re: Is there a way to....
Under the scripts tab find the starting gcode. There is probably something like
G1 X?? Y?? F???
Change the F to something slower.
KeyboardWarrior
FDWorx wrote:Slow the gantry speed down from the home axis to the point where the extruder purges. Its a little too fast for my liking, its slamming the gantry.
Thanks
Brian
If you go to the Scripts tab, and copy-paste your starting G-Code, I could change the speeds for you.
FDWorx
Thanks
Brian
Thank You,
Brian
; **** Replicator 2X start.gcode ****
M73 P0 ; enable build progress
G162 X Y F3000 ; home XY maximum
G161 Z F1200 ; home Z minimum
G92 Z-5 ; set Z to -5
G1 Z0 ; move Z to 0
G161 Z F100 ; home Z slowly
M132 X Y Z A B ; recall home offsets
M135 T0 ; load right extruder offsets
G1 X-130 Y-75 Z30 F9000 ; move to wait position off table
G130 X20 Y20 Z20 A20 B20 ; lower stepper Vrefs while heating
M126 S[fan_speed_pwm]
M140 S[bed0_temperature] T0
M134 T0 ; stabilize bed temperature
M104 S[extruder0_temperature] T0
M133 T0 ; stabilize extruder temperature
G130 X127 Y127 Z40 A127 B127 ; default stepper Vrefs
G92 A0 B0 ; zero extruders
G1 Z0.4 ; position nozzle
G1 E25 F300 ; purge nozzle
G1 X-125 Y-70 Z0.15 F1200 ; slow wipe
G1 X-120 Y-65 Z0.5 F1200 ; lift
M73 P1 ;@body (notify GPX body has started)
; **** end of start.gcode ****
KeyboardWarrior
Thanks
Brian
Thank You,
Brian
G1 Z0 ; move Z to 0
Change that bolded section to F225 and let me know how that works for you
