V5... Profiles and FW
Posted: Wed Dec 14, 2022 1:27 pm
by tobyCwood
So.. V5 will not transfer over nor import any of my custom profiles. So right at the start BAD!
Next... where is the FW setting????? How the heck does it know if it's Marlin or Sailfish?????
These are signs of no beta testing!!!!!!!!!!!!!!!!!!!!!!!!
Re: V5... Profiles and FW
Posted: Wed Dec 14, 2022 2:20 pm
by neoteric
In the output settings, you tell it what you want your output to be.. such as x3g for sailfish.
Every one of my custom profiles transferred over during the install.
Posted: Wed Dec 14, 2022 9:15 pm
by EdStreet
It must be something on your end because I used it on two setups with a dozen profiles on each machine and 100% conversion, update, and success.
Posted: Fri Dec 16, 2022 5:00 pm
by 3DWP
For me, not all profiles transfered as well. I also can't export and import them manually, it will give an error..
Posted: Fri Dec 16, 2022 10:39 pm
by Idefix
same here. My Tevo Little Monster Profile worked great.
The one for the dual extrusion printer throws a import error with no explanation given
Posted: Sat Dec 17, 2022 2:35 pm
by S3D-Jason
If you have any profiles that didn't import correctly, would you mind emailing them to our support team?
We tested literally thousands of profiles through the new migration assistant to make sure everything would import correctly, so it would be helpful to understand what was different in your profile that might have caused it not to work.
