tobyCwood
V5... Profiles and FW
So.. V5 will not transfer over nor import any of my custom profiles. So right at the start BAD!
Next... where is the FW setting????? How the heck does it know if it's Marlin or Sailfish?????
These are signs of no beta testing!!!!!!!!!!!!!!!!!!!!!!!!
neoteric
Re: V5... Profiles and FW
In the output settings, you tell it what you want your output to be.. such as x3g for sailfish.
Every one of my custom profiles transferred over during the install.
EdStreet
It must be something on your end because I used it on two setups with a dozen profiles on each machine and 100% conversion, update, and success.
3DWP
For me, not all profiles transfered as well. I also can't export and import them manually, it will give an error..
https://www.instagram.com/3dwp/
https://www.3dwp.nl
Idefix
same here. My Tevo Little Monster Profile worked great.
The one for the dual extrusion printer throws a import error with no explanation given
If you have any profiles that didn't import correctly, would you mind emailing them to our support team?
We tested literally thousands of profiles through the new migration assistant to make sure everything would import correctly, so it would be helpful to understand what was different in your profile that might have caused it not to work.
