Can No Longer Change Printer Size in V5?
Posted: Thu Dec 15, 2022 6:43 pm
by JantzenDay
Upgraded to V5 and used the migration assistant to move over my profiles. One of my profiles for a custom built Hypercube CoreXY printer is not representing the correct build size. There is no option to change this in General Options like in V4. I have manually exported and imported the profile multiple times but the build area is still too small. It should be a 300 x 300 x 400 but it is more like a 200 x 200 x 250.
Help?
Re: Can No Longer Change Printer Size in V5?
Posted: Fri Dec 16, 2022 2:21 am
by A3D-L
Hey you can change your build area in your print profile under output (already possible in V4).
Posted: Fri Dec 16, 2022 7:35 pm
by nerys
is there. some of the taps/names got moved/changed. its now under the "output" tab.
Posted: Sat Dec 17, 2022 7:40 pm
by Shaunuss
I imported my profiles from V4 into V5 and mine do not update the print volume dimensions even if I go in and edit them by hand. Just stays the same size.
